20
Sort a Ultragrid column by numeric value
the datasource for the ultragrid is SQL data rows. one of the columns "SortOrder" is int type in SQL.
 when I click on the header of this column, it does the sorting, but it sorts the column treating the numbers as strings. The result is like 1 10 11 12 .....2 20 21...
 How do I config the column setting to enable numeric sort?
 Thank you,
