Hello!
Exist an event that fires when a column change the Hidden property?
thank you
thank you Mike.
i have used this code to verify if the hidden property changes.
void grid_PropertyChanged(object sender, Infragistics.Win.PropertyChangedEventArgs e) { PropChangeInfo propertyChanged = e.ChangeInfo.FindTrigger(null); if ((PropertyIds)propertyChanged.PropId == PropertyIds.Hidden) { //Do something here...
Try Before/AfterColPosChanged.
If that does not fire, then you probably have to use PropertyChanged.
