Is there a property to turn off the visibility of the hours and only display the "All Day Events" section?
My appointments don't use hours but happen daily and I was just looking to turn off the hours section to save on screenspace.
Ian
After doing some testing this is currently available in 8.2
Set the DayView as follows:
dayview.CalendarInfo.LogicalDayOffset = TimeSpan.FromHours(0);dayview.CalendarInfo.LogicalDayDuration = TimeSpan.FromHours(1);
Using this all I see is All Day events, the scrollbar is still visible on the right but it won't let me scroll down to the hours section.
Hope this helps anyone else.
Thanks for the repsponse.
No, the control does not support that behavior. If you like you can visit http://devcenter.infragistics.com/Protected/RequestFeature.aspx and submit a request for the feature.
