1833
Cell auto width...
I've created a table with several columns and rows. I can set auto width on the cells and containing text OK, the issue is that the cells are independent of the cells above and below (rows have associated cells not the table). i.e. using auto width will give misaligned columns. I know that I can get around this with fixed width cells but then I have an issue with growing onto multiple lines when I need column width to change.
Is there a way of using auto width that will use the largest content of all cells in a given column? similar to a HTML table?
Parents Reply Children
