125
Close a usercontrol editor and prevent ultratexteditor from editing
Hi, I have set up a grid to use a user control when a cell's drop down button is clicked. The control contains a button to close the control. When pressed this fires an event to the main form. I am trying to programatically close the control but can't get it to do it. I've tried various PerformAction options (including ClodeDropDown) but nothing has worked so far. Also, I want to prevent the ultratexteditor in the cell from being edited but the ReadOnly property doesn't do this. Is there a way? Sample project is attached. Thanks
grid uc test.zip
  • 37774
    Add the following code to your Editor_DoneEditing event handler:
    ((UltraTextEditor)this.ultraGrid1.ActiveCell.EditorControlResolved).CloseEditorButtonDropDowns();
    You may also want to check for the ActiveCell being null, just in case.  You can remove the call to the PerformAction(CloseDropDown), but you may want to leave the rest.
    -Matt
