How do I create a PopupMenu that contains only images? Additionally, the images must retain their width and height (ie not be resized).
I am currently using ButtonTool as the tool, and setting
button.AppearancesLarge.MenuAppearance.Image = myImage;
contextMenu.UseLargeImages = DefaultableBoolean.True;
I guess I'm looking for a DisplayStyle like "ImageOnly". I've just had a thought that there may be a better tool than ButtonTool for this, but any help will be appreciated.
Thanks and regards
David D
That's a good idea, thanks. I'd be amazed if this really can't be done, but maybe I'm doing something extraordinary with this menu.
Dave D
The only other thing I can think of would be to set the Settings.PopupStyle of the PopupMenuTool to Toolbar. If that does not get the desired result, it is not possible and you can submit a feature request for this.
Hopefully it's obvious that I'd leave the Captions unset. The main problem is the resizing of the images, as mentioned in the initial post; they need to be "as drawn".I'm offering the user a selection of images to choose from, not text-with-icons.
Can anyone be definitive about whether this is possible?
I can do it in regular WIndows forms OK, but would rather use the nice shiny Infragistics stuff.
You can try settings the captions for all the tools to empty strings. There might be some minimum width for the text area though. I would recommend submitting a feature request for this if you do not get the desired result: http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
