is there a way to step through toolbars/toolbarbuttons with Tab-Key?
Regards Robert
Links to bugs fixed in previous hotfixes can be found here:
http://blogs.infragistics.com/blogs/vmcdonald/archive/2008/08/29/hot-fix-released-netadvantage-for-net-august-27-2008.aspx
However, the latest hotfixes do not yet have these links. This blog post will be updated when those links become available:
http://blogs.infragistics.com/blogs/vmcdonald/archive/2008/12/05/hot-fix-released-netadvantage-wpf-december-4-2008.aspx
IsMainMenuBar is set to true. I'll wait for the hotfix.
Btw, are there lists of published bugfixes and behaviour changes for every volume? I only get the #newfeatures-Link when a new volume is released, but this is more for overview but not detailed.
Its possible you do not have a main menu bar. A bug fix was recently added so that you do not need a main menu bar to give focus to one of the tools, but I don't think that hotfix has gone out yet. Try setting IsMainMenuBar to True on one of your toolbars.
Hello Mike,
this behaviour ist possible on PopupMenuTools, but I have a toolbar only with ButtonTools. I can not enter the toolbar with the Alt-key, therefore it gets no focus.
The same happens if I have a ultratoolbar with one toolbar with Popupmenutools and a second with Butontools. I can only enter the toolbar with PopupMenuTools by Alt-Key and step through, but I come not in the second toolbar.
Is there a solution for it?
Best regards
Robert
If you hit the Alt key, a tool in one of the toolbars will have focus. You can then use Tab and Shift+Tab to cycle through tools and Ctrl+Tab and Ctrl+Shift+Tab to cycle through toolbars.
