1187
Auto size first column to fit grid width
How can I setup a view only grid that has several fixed width columns and only have the first column autosize to fit the width of the grid?  I've tried several things but nothing works.
 An example of what I've tried, I want the name column to autosize to fit the grid width and have all the other columns fixed width:
Private Sub UltraGrid1_InitializeLayout(ByVal sender As System.Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles UltraGrid1.InitializeLayout
        Dim c As UltraGridColumn
        e.Layout.AutoFitStyle = AutoFitStyle.ResizeAllColumns
        For Each c In e.Layout.Bands(0).Columns
            c.CellActivation = Activation.NoEdit
            c.AllowRowFiltering = DefaultableBoolean.False
            Select Case c.Key.ToLower
                Case "name"
                    c.Header.Caption = "Campaign"
                Case "type_name"
                    c.Header.Caption = "Type"
                    c.Width = 80
                    c.LockedWidth = True
                Case "date_lastrun"
                    c.Header.Caption = "Last Run"
                    c.Width = 80
                Case "date_nextrun"
                    c.Header.Caption = "Next Run"
                    c.Width = 80
                Case "service_codes_type_name"
                    c.Header.Caption = "Codes Type"
                    c.Width = 120
                Case Else
                    c.Hidden = True
            End Select
        Next
    End Sub
