685
UltraCalendarCombo Question
I have a question regarding your CalendarCombo. I have a field in which I want to choose only the day and the month, not the year. I have used the Format property to show only day and month in the text area, but I dont want to see the year in the dropdown calendar (just the month). Is it possible?
Question number 2: I dont want the user can write in the text area, but choose the day only through the dropdown calendar. Is it possible?
Thank you
Claudio
  • 69832
    Suggested Answer
    Assign an instance of this class to the contorl's CreationFilter property:
    using nsMonthViewMulti = Infragistics.Win.UltraWinSchedule.MonthViewMulti;
    #region NoYearCreationFilter
    public class NoYearCreationFilter : IUIElementCreationFilter
        #region IUIElementCreationFilter Members
        void IUIElementCreationFilter.AfterCreateChildElements(UIElement parent)
            nsMonthViewMulti.MonthHeaderAreaUIElement headerAreaElement =
                parent as nsMonthViewMulti.MonthHeaderAreaUIElement;
            if ( headerAreaElement != null )
                TextUIElement textElement = headerAreaElement.GetDescendant( typeof(TextUIElement) ) as TextUIElement;
                if ( textElement != null )
                    nsMonthViewMulti.VisibleMonth visibleMonth =
                        headerAreaElement.GetContext( typeof(nsMonthViewMulti.VisibleMonth) ) as
                        nsMonthViewMulti.VisibleMonth;
                    if ( visibleMonth != null && visibleMonth.Month != null )
                        int monthNumber = visibleMonth.Month.MonthNumber;
                        string monthName = visibleMonth.Month.CalendarInfo.MonthsOfYear[monthNumber].LongDescriptionResolved;
                        textElement.Text = monthName;
        bool IUIElementCreationFilter.BeforeCreateChildElements(UIElement parent)
            return false;
        #endregion
    #endregion NoYearCreationFilter
    Handle the control's KeyPress event and set the 'Handled' property of the event arguments to true. This will prevent alpha-numeric keystrokes from being processed, while still allowing operational keys, i.e., navigational keys, F4, etc.
