I am using BarChart3D and it seems that when there is more than 10/15 rows of data, I don't get a graph.
Following query on Northwind returns 89 rows and graph generated is pic 1 (below)
select a.customerID as 'Customer', count(b.OrderID) as 'Order Count'FROMCustomers a, Orders b WHERE a.CustomerID = b.CustomerID GROUP BY a.CustomerID ORDER BY 2 DESC
Same query with Top 10 selected and graph generated is pic 2 (below)
select Top 10 a.customerID as 'Customer', count(b.OrderID) as 'Order Count'FROMCustomers a, Orders b WHERE a.CustomerID = b.CustomerID GROUP BY a.CustomerID ORDER BY 2 DESC
Question - what setting do I need to change so that I get graph no matter how many rows are there?
there is no setting that does what you're asking. i recommend one of the following solutions:
1: place the chart in a panel with AutoScroll = true and set the chart's Height to a very large number e.g. 2000.
or
2: use a 2D bar chart and enable the scrollbar on the Y-axis.
