1165
Row Template Editor and Custom Biz Objects
This is an urgent issue, so a quick response would be appreciated.
We are attempting to bind custom biz objects to the ultra grid and also to use the row template editor.
When binding objects with DateTime or numeric properties, we need users to be able to enter an 'empty string' in some cases, but the row template editor is having a problem with this.  For example, if we use the following property and then try to remove an existing date, the template editor will not respond to the OK or Cancel buttons.  If we use a datatable with the same data type, everything works fine:
Public
Property Col2() As System.DateTime
Get
If _Col2 = DateTime.MinValue Then
   Return ""
Else
   Return _Col2.Date.ToString
End If
' Return _Col2
End Get
Set(ByVal value As System.DateTime)
   _Col2 = value
End Set
End Property
