I put a combo editor in tree node using the following code, and subscribe the KeyUp event of the embedded editor. It works well before I set DropDownStyle to DropDownList.
After setting DropDownStyle to DropDownList, I found that editor_KeyUp is not invoked when the keyboard is pressed.
Could anyone tell me what the problem is? Thanks a lot!
UltraComboEditor editorControl= new UltraComboEditor();
editorControl.DropDownStyle = DropDownStyle.DropDownList;
node.Cells[column].EditorControl = editorControl;
EmbeddableEditorBase editor = node.Cells[column].EditorResolved;
editor.KeyUp += new KeyEventHandler(editor_KeyUp);
Mike,
You are right, the KeyUp event of the tree control is fired.
My solution is to subscribe the event of the tree instead of the editor although it seems a little weird to me.
Thanks!
My guess is that the tree is processing the KeyDown message and not the editor. Does the KeyUp event of the tree control fire?
