805
Changing underlying Entity causes heartache
I'm using an UltraWinGrid that's bound to a IList of AccountRecords. I diligently laid out the Grid in the designer and hid many fields, but later had to go back and add another property to the AccountRecord class. When I ran the app again, every single item in the AccountRecords was visible, and the editor appeared to believe I had not bound to a DataSource.
At first I wrote it off as "one of those things", but when I did the same to my QuoteRecord the same thing happened to the two grids that used it.
This is very annoying. Is there any way to avoid this?
Maury
