I need to add a PopupGalleryTool in a ultraTreeNode, just instead of the leftImage, with keeping the text of the node just after this control, how should i proceed if that is possible?
thanks in advance
Ok , i did it using a customized UIElement ,
Thanks Mike
There's no way to embed a tool or a toolbar inside a node. You could use an image that looks like the tool, but that's about it.
