685
Graphic problem on x64 OS - UltratoolbarManager
I have a problem with my application under Windows 7 64 bit and Windows Vista 64 bit. I am using an UltratoolbarManager with Ribbon and the MDI form shows different under XP/Vista 32bit or under Windows7/Vista 64 bit.
Here is an example:
The first is how the form is showed in XP 32 bit / Vista 32 bit and it's the correct one.
The second is the same form on Windows 7 64bit / Vista 64 bit with NetAdvantage 8.3 controls.
The third is the same form on Windows 7 64bit / Vista 64 bit with NetAdvantage 9.2 controls.
As you can see, there is a sort of horizontal line just under the title and the maximized, minimized and close buttons aren't visible at the top right.
Any idea of what could be the problem?
Thanks in advance
Claudio Di Flumeri
  • 20872
    Hello Claudio,
    It seems that you are not using the latest service release for NetAdvantage 9.2.20092.2058, which you could download from out web site and that's why you are not seeing the maximimized, minimized and close buttons when the IsGlassSupported property of the UltraToolsBarsManager is set to True, if you have set it to False it should appear as in the 32bit machines.
    Sincerely,
    Danko
    Developer Support Engineer
    www.infragistics.com/support
