This is probably a stupid question, but I'm just starting out with the Infragistics controls. I noticed that text in the UltraTextEditor control is not fully displayed even though there is adequate room for the missing character. The same text does display in a Windows text box of the same size (actually, slightly smaller). The UltraTextEditor seems to have more padding around the text, which I suppose is causing my problem, but I don't see any property to control it.
Changing the Appearance.TextTrimming property from Default to None solved the problem, but I don't see why the text was being trimmed if there is room for it.
Yeah, I think this is pretty much what I was saying above, it's the difference between GDI and GDI+. The MS TextBox is a wrapper for the Windows TextBox which uses GDI. But DotNet controls such as UltraTextEditor use GDI+, which is supposedly better for resolution independence on different machines.
You could set AlwaysInEditMode to true on the UltraTextEditor to get it to look like the MS TextBox, but you will lose some functionality like gradients or hatch styles (which you probably don't need).
You could also set the TextRenderingMode on the UltraTextEditor to GDI.
Here's a screen copy. All three controls (Windows text box, UltraTextEditor, UltraTextEditor with text trimming set to none) have a width of 72 and the same text (999,999,999). I also noticed that the text is displayed completely when the control gets the focus. The environment is Windows 7 32-bit with VS 2010. I could send you the code, but I got this just by dropping the 3 controls on a form and setting the width and text properties.
It's hard to guess without seeing what you are seeing. Can you post a small sample project or even a screen shot?
My guess is that this is the difference between GDI (which is what the MS TextBox uses) and GDI+, which is what the UltraTextEditor uses when it is not in edit mode. You can easily test this by setting the TextRenderingMode on the UltraTextEditor to GDI, or setting AlwaysInEditMode on the the UltraTextEditor to true.
