703
add new row; valuelist; summaries
Hi ,
I have a Wingrid with databinded with binding list. I am adding a new to row to the grid. In my grid i have First 3 columns
Project, Milestone and Class are of style dropdown .
Scenario is
1. When I add a new row to grid the Dropdown will be active for only newly added rows. Rows having ID or existing rows must be non editable(basically first three columns), rest are editable.
2. I have added valuelist to my dropdown , My sequence is On selection of project (in new row only) will populate the
milestone valuelist and on changing the milestone class valuelist will be populated.
3. Also i have seven more columns from SundayHours to SaturdayHours, whose summation, i want to display at the footer of the grid(Column wise). Somewhat similar Infragistics Silverlight Grid's -DataColumn.FooterText  property.
But while searching i came across mike's answer that no footer summary exists in wingrid . So any workaround for that.
