690
Text rendering changes when UltraTextEditor gets focus
When the control gets focus, the spacing between letters seems to decrease. I think this is distracting. I'm able to stop this behavior by setting the TextRendering to GDI, but I'm wondering if I'm losing anything by doing so or if there's another way to accomplish this.
  • 469350
    The reason this happens is that the control draws the text using GDI+ (the preferred method in DotNet), but when it goes into edit mode, it uses an inbox TextBox control, which uses GDI.
    You will see the same difference if you have a label and a TextBox with the same text.
    Anyway, using GDI is a bit slower in DotNet, but for a single TextEditor, you probably will not see any different.
