125
localization of ultraGanttView and context menu on dependency line
question to localization:
in GridView:  i succeeded in changing captions for example from duration to Dauer. But how to change the units in this column from hours to Stunden, day(s) to Tag(e) and so on?
I succeded to change the field names in diaolog "Field chooser" but how to change the title of this dialog?
I found http://help.infragistics.com/Help/NetAdvantage/WinForms/2010.1/CLR2.0/html/WinSchedule_Resource_Strings.html
but I don´t know how to apply them.
question context menu in GanttView:
Is it possible to install a context menu on dependeny lines? How?
Thanks for help,
joerg
  • 69832
    Verified Answer
    You can localize the unit of time tokens in the duration field's editor like so:
    Infragistics.Win.UltraWinGanttView.Resources.Customizer.SetCustomizedString(
        "TimeSpanEditor_DayDisplayString_Singular",
        "tag");
        "TimeSpanEditor_DayDisplayString_Plural",
        "tage");
    Each unit of time has a corresponding string resource, following the same convention as above, i.e., WeekDisplayString, HoutrDisplayString, MinuteDisplayString, and each has a Singular/Plural variant
    You could handle the control's ContextMenuInitializing event and add a menu item for the dependency, like so:
    using nsGVElements = Infragistics.Win.UltraWinGanttView.UIElements;
    this.ganttView.AutoDisplayDefaultContextMenu = AutoDisplayDefaultContextMenu.GridAreaOrChartArea;
    this.ganttView.ContextMenuInitializing += new ContextMenuInitializingHandler(ganttView_ContextMenuInitializing);
    void ganttView_ContextMenuInitializing(object sender, ContextMenuInitializingEventArgs e)
        UltraGanttView control = sender as UltraGanttView;
        UIElement controlElement = control.UIElement;
        Point clientPos = control.PointToClient(Control.MousePosition);
        UIElement elementAtPoint = controlElement != null ? controlElement.ElementFromPoint( clientPos ) : null;
        nsGVElements.TaskDependencyLineUIElement lineElement =
            elementAtPoint as nsGVElements.TaskDependencyLineUIElement;
        if ( lineElement != null )
            TaskDependency dependency = lineElement.GetContext( typeof(TaskDependency) ) as TaskDependency;
            IGMenuItem menuItem = new IGMenuItem("Dependency");
            e.ContextMenu.MenuItems.Add( menuItem );
