265
NullText on UltraGridCell
Hello-
This post, even though it's old, suggests what I'd like to do should be possible:
http://forums.infragistics.com/forums/p/5107/23272.aspx#23272
I've got an UltraGrid with two columns.
Column 0 is a UltraCombo loaded with a ValueList.
Column 1 is a TextBox.
What I'd like to do is set the NullText property of column 1 whenever the value of column 0 changes.
Using that post above as a model, I've attached a new editor to the cell in column 1 as follows:
UltraTextEditor editor = new UltraTextEditor();
((ISupportInitialize)editor).BeginInit();
editor.NullText = "This is NullText";
((ISupportInitialize)editor).EndInit();
cell.EditorComponent = editor;
Unfortunately, "This is NullText" never displays even though the underlying value in column 1 is in fact null.
NOTE: "This is NullText" is just a test for this post.  What I need to do eventually is assign editor.NullText a value that is associated with the value chosen from the dropdown in column 0.
First, although the above post SUGGESTS this is possible, is what I need to do possible?
If so, what have I done wrong with my code or how should this be handled differently?
Thank you.
