I'm using Infragistics NetAdvantage 2008.1. I have ultraGrid which is bound to a datasource, furthermore i am adding extra columns specifying several dates. this grid is intended to be used as a timeregistration grid, wherein you enter the hours in the date columns specifying your time spent on each date.
It would like to add a scrollbar which scrolls only the date columns (as in MS Project), so that whenever the scrollbar is used the databound columns provided by the datasource is still present/visible.
Can anyone provide me with a way to do that?
Best Regards
Dennis Tycho Nielsen
I have found another post where in I found a solution to my problem, by using Fixed Headers :-)
