Sometimes after clicking update ind the ultraprintpreviewdialog I get an exception like this:
{"Cross-thread operation not valid: Control '' accessed from a thread other than the thread it was created on."} Stack Trace: at System.Windows.Forms.Control.get_Handle() at System.Windows.Forms.Control.SetParentHandle(IntPtr value) at System.Windows.Forms.Control.ControlCollection.Remove(Control value) at Infragistics.Win.UltraWinChart.IGWinTooltip.Dispose() at Infragistics.Win.UltraWinChart.UltraChart.Dispose(Boolean disposing) at System.ComponentModel.Component.Finalize()
I have no clue why it is happening, seems to happen only when visual studio is ib debug mode.
Sometimes after the 5th preview update, sometimes later... seems a bit randomly
Do you have any idea what could go wrong here? Seems to happen just when UltraChart is Disposing.
We fixed one issue when the chart tooltip is showing. This might fix your case as well. Can you try applying the latest service release and see if the issue still exists? If this doesn’t help, can you send us a sample project so we can investigate it?
