2715
different button on same column
hi!
I have a grid with a button column, wich holds a button who's function is :
- insert new row - for the last row in the grid - has a "+" on it
- delete - for the other rows - has  an "x" on it
how could i implement this, because i've tried, and i keep getting in the same issue : the "+" remains in all newly inserted rows.
  • 48586
    I am just checking about the progress of this issue. Did you solve your issue accordingly to the information that I provided you? Did you test the sample I have sent to you?
    Let me know if you need any further assistance.
  • 48586
    Suggested Answer
    Hello Marius,
    Based on your requirements and Brian suggestions I have created a simple sample to illustrate how you could achieve your goal.
    Please test the sample at your side and Let me know if you have any further questions or if I misunderstood your scenario.
    WinGridDifferentButton.zip
  • 69832
    You didn't provide a lot of detail here about your implementation, so it is difficult to speculate about what might be causing the problem. I don;t know if this helps you but UltraGridRow exposes an 'IsAddRow' property, so I would think you would want to use that to determine whether the "+" or "x" is drawn.
