Hi guys.
I have a form that contains 3 wingrid. 2 datagrid works fine with row deletion, but not the other 1.
All of them have a delete button in each row, and all of them use the same codes.
Under clickcellbutton event for 3 datagrids, I have this code.
e.Cell.Row.Selected = True With dgSample.Selected If .Rows.Count > 0 Then dgGrid.DeleteSelectedRows(True) End If End With
The problem is on a datagrid. If the datagrid consists of 3 rows of records, when I delete second row, the third row become nothing.
This doesn't happen in the other 2 datagrid.
Please help.
I don't understand what you mean by "when I delete second row, the third row become nothing".
Are you saying that you are deleting the second row and the third row is removed instead of the second? Or that both the second and third rows are removed?
I don't see how the grid could be causing either of those issues. My best guess would be that something in your code or in the data source is removing the wrong row.
