Would anyone have a Windows XP style sheet under their hand?
I'm using .NET Volume 2010.2.
Thank you
Unfortunately, nothing resemble the WinXP (Luna) theme inside the existing Infragistics library. My guess is that it would have to be built from scratch.
Just checking if the latest reply helped you out and if you require any further assistance on the matter.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
As far I can see we don’t have any build in style that mimic any of the Windows Xp styles. You can find the build in ISL files installed on your machine under your user account to find some that probably will be close it this style and modify it:..Documents\Infragistics\NetAdvantage 2010.2\Windows Forms\AppStylist for Windows Forms\Styles
I hope this helps.
I would be looking for an ISL sheet which would mimic the Luna theme of Windows XP.
Can you please clarify which exact style sheet are you looking, are you mean you look for ISL of Css file?
Thank you.
