1878
UltraMaskedEdit showing credit card expiry
maybe there is an easy solution for my purpose but I cannot find it. I want to have a text editor where the user may enter the expiry date of a credit card in format mm/yyyy. UltraMaskedEdit control already comes very close by setting the input mask to mm/yyyy but I want to give the user also the possibility to see what format he has to enter so ideally the text editor should display MM/YYYY when the text editor does not have the focus. I did a workaround by setting the text of the text editor to MM/YYYY when the form loads, in the Enter event I clear the text and set the input mask with mm/yyyy. In the Leave event I clear the input mask and set Text to MM/YYYY again if user has not input any data. This workaround works but I want to use databinding so it's getting a little bit clumsy so I'm asking if there is a better solution, maybe with another control?
Regards, Wolfgang
  • 469350
    Hi Wolfgang,
    The only way I can think to do this would be to use a DrawFilter or a CreationFilter to change the display without changing the value. Here's a quick example.
        internal class DateMaskCreationFilter : IUIElementCreationFilter
            #region IUIElementCreationFilter Members
            void IUIElementCreationFilter.AfterCreateChildElements(UIElement parent)
                // Do nothing
            bool IUIElementCreationFilter.BeforeCreateChildElements(UIElement parent)
                MaskedEditUIElement maskedEditUIElement = parent as MaskedEditUIElement;
                if (maskedEditUIElement != null)
                    // When the control has focus (and is therefore in edit mode), do nothing.
                    UltraMaskedEdit ultraMaskedEdit = (UltraMaskedEdit)maskedEditUIElement.Control;
                    if (ultraMaskedEdit.ContainsFocus)
                        return false;
                    maskedEditUIElement.ChildElements.Clear();
                    TextUIElement textUIElement = new TextUIElement(parent, "MM/YYYY");
                    textUIElement.Rect = parent.RectInsideBorders;
                    maskedEditUIElement.ChildElements.Add(textUIElement);
                    return true;
                // do nothing
                return false;
            #endregion
    I'm not accounting for localization here, so you might want to change the text string I used to account for the date separator character and you might want to adjust it based on the actual input mask being used instead of hard-coding the string, but this should point you in the right direction.
