140
PerformAutoResize After Removing Rows
Would there be an issue with using PerformAutoResize after removing rows from a dataset?
Here is what I am doing.
  • I populate my dataset
  • I remove some duplicate rows from the tables.
  • I then create relationships between each table.
  • Set the dataset to the .DataSource
  • The .PerformAutoResize(PerformAutoSizeType.AllRowsInBand, True) is done in the InitializeLayout event for each band.
The last step is where it hangs. I have never had a problem with it in the past but since I have added the piece to remove duplicate rows in the datatable, I have run into trouble.
Any Ideas?
Jeff
  • 469350
     I can't see any reason why removing rows would cause a problem. So you are saying that if you comment out the code that removes the duplicate rows it works fine?
