290
BeforeColPosChanged/AfterColPosChanged events are not firing when setting Column Header Fixed property
I have noticed that the BeforeColPosChanged/AfterColPosChanged events are fired if you click on the "Pin/UnPin" icon in the column headers but are NOT fired when you programmatically set the Header's Fixed property to true/fase.
This same behavior is also true for the BeforeGroupPosChanged/AfterGroupPosChange events for the GridGroup Header.
I, also, noticed that the BeforeGroupPosChanged/AfterGroupPosChange do not fire when the GridGroup's Header is hidden/unhidden which does not match the behavior of the Grid Column's Header.
Not sure if this is a bug or I am not understanding something, but I would beleive that the behavior would be consistent between the different actions!
