First row in the child band becomes Active Row even when I am editing another child row.
The scenario is not straight forward. It does not always occur, after a few clicks on another cell its not reproducable. And the base grid (derived from UltraWinGrid) does override number of properties and does event handling. I could not spot anything obvious from the base grid code.
I debugged the callstack for by overriding the OnActiveRowChange.
Infragistics2.Win.UltraWinGrid.v10.3.dll!Infragistics.Win.UltraWinGrid.UltraGridBase.SetActiveRow Infragistics2.Win.UltraWinGrid.v10.3.dll!Infragistics.Win.UltraWinGrid.UltraGrid.EnsureTempActiveRowAssigned Infragistics2.Win.UltraWinGrid.v10.3.dll!Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint
Would appreciate any pointers
My colleague investigated the issue and found the solution on the forum. The problem was solved by turning off SyncWithCurrencyManager.
I guess the problem is more to do with general .net databinding and how grid integrates with CurrencyManager.
I have experienced a similar problem.
It only occurred when selecting a child row of the first row. The problem went away when I moved the setting up of data bindings from the form constructor to a handler of the grid event InitializeLayout.
Regards Martin
I am just checking about the progress of this issue. Let me know If you need any further assistance regarding this matter ?
Could you please provide me the exactly steps which I should follow in order to reproduce this issue on my machine. If it is possible could you please post a simple sample which demonstrates your issue. Also please let me know the exactly version of Infragistics which you are using.
I am waiting for your details.
