Hello wonderful support :)
i have a UltraTree with NodeStyle as a CheckBoxTriState .
i am looking to make it as a standard intuitive functionality tree as seen in Windows OS.
basically for the ParentNode to correspond to the selection of the ChildNodes and vise versa
this can be defined by the following rules :
1. when only part of the ChildNodes are checked then the ParentNode is at the TriState
2. when none of the ChildNodes are checked then the ParentNode is unchecked as well
3. when all the ChildNodes are checked then the ParentNode will also be checked.
4. when checking the ParentNode all the ChildNodes will be checked
5. when unchecking the ParentNode all the ChildNodes will be checked.
example :
i am not looking for you to write the code for me , i can handle coding the above stated rules but was wondring if this can be achieved by "playing" with the properties/overrides in ways that are more familiar to you compared to me. unless you might have an example for me ?
many thanks :) again and again
I am glad to hear that you were able to solve this. Thank you for your feedback and for sharing this with our community.
i found a post at the forum that had exactly what i've described
here is the link :
http://news.infragistics.com/forums/p/11971/349158.aspx#349158
