1935
UltraGrid scroll happening when collapse/expand
Hi
i have UltraGrid with 2 bands (parent /child) and i noticed that sometimes when the i expand or collapse then the vertical scrolling possition is changed. this happens when the vertical possition is not at the top
for example
when i expand about 4 parents to show their child band then and then scroll down and then collapse the lower parent to hide its child then the whole grid slides downwords. it complicates what i am trying to acheive - syncing two ultragrids side by side, but i am trying to take care of that,
so i play with ActiveRowScrollRegion.ScrollPosition but the problem is that i am unable to catch the correct value of it inorder to assign it to the second grid .  and perform something like
ug2.ActiveRowScrollRegion.ScrollPosition = ug1.ActiveRowScrollRegion.ScrollPosition;
here is the events flow that i understand happening after collapse/expand click
1. _BeforeRowCollapsed/Expanded
2. _AfterRowCollapsed/Expanded
3. _BeforeRowRegionScroll
4. _AfterRowRegionScroll
the problem that the ug.ActiveRowScrollRegion.ScrollPosition is not changing during this flow. only sometime after the 4th event mentioned above. i know this because at the  ug_Paint event i am constatly writing the ug.ActiveRowScrollRegion.ScrollPosition and after the whole operation was completed it has different value then the value it had during all 4 events stated above.
so my assumption that there is another event after _AfterRowRegionScroll happening which during that event the ug.ActiveRowScrollRegion.ScrollPosition gets changed and at that point i need to do "my thing".
any thoughts?
