885
Set Widths Of UltraDropDown Columns?
I'm perplexed - trying to set the column widths of an UltraDropDown to suit the contents of the columns of the control, and want the AllRowsInBand option, but I don't seem to be able to get it right?
I have two visible columns, a code, and a description.
I put code in the InitializeLayout event as shown below.
However, the description is never resized to show the full contents of the field - can I get a clue? TIA
Private Sub udrpActivities_InitializeLayout(sender As System.Object, e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles udrpActivities.InitializeLayout
        Dim column As UltraGridColumn
        For Each column In e.Layout.Bands(0).Columns
            If column.IsVisibleInLayout Then
                column.AutoSizeMode = ColumnAutoSizeMode.AllRowsInBand
                column.PerformAutoResize()
            End If
        Next
    End Sub
  • 48586
    Hello, ­­­­­
    I am just checking about the progress of this issue. Let me know If you need my further assistance on this  issue?
    Thank you for using Infragistics Components
  • 48586
    Hello ,
    As far as I am understand from the description of your scenario, you want to resize UltraDropDown, so that all columns (in your case code and description columns to be resized based on the content of their cells) all visible columns to be resized, based on their cells. The code which you are testing works, and it should be in some event, where the column of UltraDropDown are already populated with data. So I have tried to put your code in AfterDropDown event of UltraDropDown and this works for me. Please see attached sample.
    Please let me know if you have any further questions or if I am missing something
    91782.zip
