1935
UltraTree - "display member" property?
I have a tree with ViewStyle = Infragistics.Win.UltraWinTree.ViewStyle.Standard;
the datasource is a self referancing table, which i found how to bind properly here :
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10084
how do i set the "display member" ? because the ViewStyle is Standard then the node text  is the first column of the data table / data source. of course i can controll the way i bring the data and put the column i want to display  first and then all the rest but i was just wondering if i can set it in the properties somehow?
i.e.
This way it will work  fine and display fine
dataTable.Columns.Add(
"Name", typeof(string));
"managerID", typeof(int));
"ID",typeof(int));
but this way it will show me the managerID as the node text.
dataTable.Columns.Add("managerID", typeof(int));
dataTable.Columns.Add("ID",typeof(int));
dataTable.Columns.Add("Name", typeof(string));
Parents
No Data
Reply Children
