315
How to detect when a row is clicked by user (mouse selection only, not keyboard).
I need to perform an action when user specifically clicks a row with mouse.
AfterSelectChange event fires even when user selects the row using arrow keys. Also, it won't fire twice if I click the same row twice. Not desirable.
MouseClick event fires even when user clicks outside of the rows (group by area, headers, scrollbar, etc). So, this won't do either.
ClickCell event won't fire because CellClickAction = RowSelect.
Is there any property or arguments in some event that will do the job.
  • 9298
    Verified Answer
    You will find the answer in this article from our on-line documentation:
    http://help.infragistics.com/Help/NetAdvantage/WinForms/2012.2/CLR4.0/html/WinGrid_Determining_Which_Row_the_User_Clicked.html
    Handle the MouseUp event of the WinGrid and put in something like this:
    UIElement aUIElement =   this.ultraGrid1.DisplayLayout.UIElement.ElementFromPoint(new Point(e.X,e.Y));
     // Declare and retrieve a reference to the row
    UltraGridRow aRow = (UltraGridRow)aUIElement.GetContext(typeof(UltraGridRow));
     // If a row was found display the band and row index
    if(aRow != null)
     this.ultraTextEditor1.Text += "Band("   + aRow.Band.Index.ToString() + ") Row.Index=" + aRow.Index.ToString() + "\n";
    else
    this.ultraTextEditor1.Text += "* no row associated with this location *\n";
    Let use know if you have further questions.
