1934
Getting summary value as soon as databinding is complete
 I have my UltraCalcManager set to DeferredCalculationsEnabled = false and the LoadStyle of the UltraWinGrid set to PreloadRows.  I need to get the totals for my UltraWinGrid directly after I bind the data because I need to display some other data in a pivoted form based on the totals.  Is there a way that I can force calculations to occur immediately or receive some notification when everything has been evaluated?
 I have tried setting UltraCalcManager CalcFrequency to Async or Sync with no difference and I have tried using the SummaryValueChanged event of the UltraWinGrid but since the values aren't calculated until the GroupByRows(where my Summaries are) are visible the event isn't fired.  I need values calculated immediately, is this possible?
