Hi
The end point of the progress bar moves when you resize the control, which it shouldn't. I've attached an example showing this, if you resize the control below a certain width you will see the end point of the progress bar on task 3 moves.
The issue appears to be that it is using the visible width of the task as the total length of the task, rather than the total width of the task (including the portion which is not on screen). In the example you can see that once you resize the control so that some of task 3 is off the screen the progress bar (which is at 50%) is always sized to 50% of the size of the visible part of the task. The tooltip however reflects the correct info.
This is a big issue to us on an about to go live healthcare system, so a quick fix would be much appreciated.
Thanks, Tom
The issue has been addressed in service release versions WinForms_14.1.20141.2035, WinForms_13.2.20132.2054.
Let me know if you have any questions regarding this matter.
Thank you for reporting this. I was able to reproduce the behavior and noticed that depending on the visible portion of the task, the progress bar will change based on what the PercentageComplete property is set to. I have opened a private case for you so that I can link it to an internal development issue. This way you will be notified automatically when the developement issue is updated. The case number is CAS-135578-T1L5G6. You will see it located here: https://ko.infragistics.com/my-account/support-activity
