110
Sorting a column other than the Group By Column
I have a scenario where i have a group by column which is a concatenation of a numeric value and a string value.
But when i try to sort the column, i want the result set to be sorted on the numeric value and not on the concatenation.
There is a column in the grid which is hidden and which has the numeric values of the group by column.
I tried using the _AfterSortChange(object sender, BandEventArgs e) event and then adding the sort by
e.Band.SortedColumns.Add("NumericValues", sortIndicator == SortIndicator.Descending);
But then it removes the group by and just sorts by the numeric column. But i also want to keep the group by column.
How can i fix this scenario. Help needed please.
Shailendra
Parents
No Data
Reply
  • 110
    Verified Answer
    I added the below class
    class MySortComparer : IComparer
    public MySortComparer()
    public int Compare(object x, object y)
    UltraGridCell xCell = (UltraGridCell)x;
    UltraGridCell yCell = (UltraGridCell)y;
    xCell = xCell.Row.Cells["NumericValues"];
    yCell = yCell.Row.Cells["NumericValues"];
    int val1 = Convert.ToInt16(xCell.Value);
    int val2 = Convert.ToInt16(yCell.Value);
    if (val1 < val2)
    return -1;
    else if(val1 == val2)
    return 0;
    else
    return 1;
    and then added the below line in the _AfterSortChange(object sender, BandEventArgs e) event.
    e.Band.Columns["NumericValuesAndStringValues"].SortComparer = new MySortComparer();
    It works fine. But is this right and is there a better way to do it.
    Shailendra
Children
