100
Responding to Keypress Events in the UltraDropDown
Does someone know of a way to change the default timeout period for a keypress event associated with the searching of a UltraDropDown?  If the user types the letters fast enough it will be considered a continuous search in the UltraDropDown; however, if they are a bit slow then the search string builder resets and the user ends up somewhere else in the dropdown list.  The UltraGrid has a nice search helper class that can be attached to provide column searching where you can change the timeout period.
Also: does someone know of a way to respond to the keypress events when the UltraDropDownis in a UltraGrid ?  I would like to enable the up and down arrow for the user to navigate in the dropdown list.
