I found a bug of XamRibbon with sub items (e.g. RibbonTabItem).
For example, I have 3 tabs, Format (O), Insert (I), Font Section (JS), and make Format tab visible by default.
Steps:
1. press Alt so that short cuts of tabs shows up;
2. press I to switch to Insert tab;
3. click the tab header of Format to switch back to Format tab;
4. now if you click on Insert tab, nothing will happen, it will not switch to Insert until waiting for a while or changing the visual elements (if you minimize the app or make the ribbon hidden, then everything goes back).
Is it a known issue? are there any solutions or workaround plz?
Thanks for help.
Nathan.
We have shipped out a new service release where the issue is resolved. You can download the Service Release by logging in our web site and then going to Keys and Downloads page.
I created the following case for you: ' CAS-170823-Y9C2F9 ' and will update you through it. You could see it in your account in the 'Support Activity' page.
