I'm using the XamDataGrid and adding a new row. what I want to do is when I click on the new row cell and start typing, I will capture the RecordUpdatingEvent in the View Model.
this is my code (I"m using Caliburn Micro, so cal: is actually referring to it):
<ig:XamDataGrid x:Name="MyInfoDataGrid" DataSource="{Binding SpecificDataList, Mode=TwoWay}"
<i:Interaction.Triggers> <i:EventTrigger EventName="RecordUpdating" > <cal:ActionMessage MethodName="MyRecordUpdating"> <cal:Parameter Value="{Binding ElementName=MyInfoDataGrid}" /> <cal:Parameter Value="RecordUpdatingEventArgs" /> </cal:ActionMessage> </i:EventTrigger> </i:Interaction.Triggers>
and in my ViewModel:
public void BinsRecordUpdating(object sender, RecordUpdatingEventArgs e) { DataRecord temp = e.Record; }
I can get the sender object, but I can't get the RecordUpdatingEventArgs. it shows up as null.
i'm wondering how do pass the evetArgs as the parameter for anything similar to this event? or i'm using a totally wrong method to do it?
thanks a lot,
Francis
Hi Francis,
Thank you for your feedback
I am glad that you have resolved your issue and I believe that other community members may benefit from this as well.
Please let me know if you require any further assistance on the matter.
Sincerely,ZhivkoAssociate Software Developer
I got it. it's a Caliburn Micro syntax: $eventArgs.
thanks
anyone can help? much appreciated. thanks!
