Is it possible to enlarge and bold the gallery menu tool button?
because currently the size of the gallery tool dropdown button as it is too small and tends to be overseen
As you can see in the red box of Picture 1 the current solution provides only a very small arrow.
The used in the attached screenshot is the default XamRibbon style. In order to achieve the described behavior, I created a small sample where in XamRibbon's Tab named "Home" I added a RibbonGroup - "Group" and this group contains the MenuTool and the GalleryTool in it. The default styles could be found in the Infragistics folder. There you can find the styles you need and if neccessary to change them.
Attached you will find my sample for your reference. Please test it on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me along with steps to reproduce. Alternatively, if the behavior cannot be replicated please feel free to provide your own sample. Remove any external dependencies and code that is not directly related to the issue, zip your application and attach it in this case.
Sincerely,
Teodosia Hristodorova
Associate Software Developer
2450.GalleryTool_CAS-205896-K2P3T5.zip
hi,
can we apply customize style to the menutool buttons to have desired result?
even i would be happy to have the below tool menu style.
can you help me to achieve the above style for my tool menu button, as right now my tool menu button is not much bold and large.
Thank you for the provided image. I assume that you are referring to the MenuTool buttons. In order to ensure that we are on the same page, I have attached a screenshot where they're highlighted. After further researching your query I determined that changing button`s size is not available with the built-in functionality of the toolset. The reason behind this is that we follow Microsoft Guidelines on constructing an actual Ribbon and in case that the MenuTool is re-templated all its built-in functionality will be lost. My suggestion is to submit a new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com >.
There are many benefits to submitting a product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible.
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics.
