233
Binding problem
I'm using a XamlDataGrid bound to a set of Business Objects, this objects has the following structure:
public class MyObject
        private MyObject2 _o2 = new MyObject2();
        public MyObject2 O2
            get
                return _o2;
            set
                _o2 = value;
public class MyObject2
        public string Name
            get;
            set;
Due to some technical requirements the grid datasource is bound to a list of MyObject and i need to display the property Name of the MyObject2 as a column on the grid. So for achieving this I'm using the following XAML code for the field declaration.
                       <igDP:Field Name="O2.Name"
                            ColumnSpan="1"
                            RowSpan="1">
                            <igDP:Field.Label>
                                Name
                            </igDP:Field.Label>
                        </igDP:Field>
 After doing this binding, nothing on the grid is rendered, i think that it crashes. So i will like to know why is this happening, and how can i achieve this type of binding.
After I remove this column, for testing purposes, the grid is rendered, but this message is appearing on the output window of visual studio.
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='36939349'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='RecordSelector: DataRecord- 1 jjj: xxxxxxx'; TargetElement.HashCode='38118303'; TargetElement.Type='Infragistics.Windows.DataPresenter.RecordSelector'
