40
Display Image on Carousel in Winforms App
I have added the datapresenter in carousel view to a windows forms application. I found the xaml code in the help doc to display an image. How can I do this using equivalent vb code inside the windows form application. The carousel is bound to a sql data source.
Thank you.
  • 30945
    I have created a sample application for you that demonstrates how you can add a XamDataPresenter with CarouselView in Windows Forms Application. I have used a collection as DataSource for the XamDataPresenter. The collection is filled manually in the constructor of the UserControl that contains the XamDataPresenter. You can provide your own logic in order to fill the collection using a sql data source.
    If you need any further assistance please do not hesitate to ask.
    Sincerely,
    Krasimir
    Developer Support Engineer
    www.infragistics.com/support
    CarouselInWinFormsAppVB.zip
