370
Custom Template implementation for Row summaries
The datagrid in my application has multiple Summarydefinitions as row summaries for the same field.
 They are placed one below the other. I want to right align the value part of the summary definitions. I am
finding difficult to implement a custom template targeting the rowsummary. Is there a way by which we
make use of the grid in the custom template placing  header and value in seperate columns so that we
can align the items appropriatly?
ex: Stringformat = "Amount: {}{0:C}"  placing Amount in one column and the value in other.
Please do send me a code snippet if this is possible.
Thanks in advance.
  • 2426
    Verified Answer
    Toreador,
    I don't see a Mask property for the Texbblock so using the xamTextEditor, I believe you would have to bind the xamTextEditor's Value property to the value of the SummaryResultPresenter's SummaryResult.Value Path.
  • 69686
    Verified Answer
    The following code snippet will do the trick:
            <Style TargetType="{x:Type igDP:SummaryResultPresenter}">
                <Setter Property="Padding" Value="1,1"/>
                <Setter Property="Template">
                    <Setter.Value>
                        <ControlTemplate TargetType="{x:Type igDP:SummaryResultPresenter}">
                            <Border
    Background="{TemplateBinding Background}"
    BorderBrush="{TemplateBinding BorderBrush}"
    BorderThickness="1"
    Padding="{TemplateBinding Padding}"
    ToolTip="{Binding Path=SummaryResult.ToolTipResolved, RelativeSource={RelativeSource TemplatedParent}}">
                                <Grid Margin="2">
                                    <Grid.ColumnDefinitions>
                                        <ColumnDefinition Width="Auto"/>
                                        <ColumnDefinition Width="5*"/>
                                    </Grid.ColumnDefinitions>
                                    <TextBlock Grid.Column="0" Text="{Binding Path=SummaryResult.SummaryDefinition.Calculator, Mode=OneWay, RelativeSource={RelativeSource TemplatedParent}}" HorizontalAlignment="Left"/>
                                    <TextBlock  Grid.Column="1" Foreground="BurlyWood" Text="{Binding Path=SummaryResult.Value, Mode=OneWay, RelativeSource={RelativeSource TemplatedParent}}" HorizontalAlignment="Right"/>
                                </Grid>
                            </Border>
                        </ControlTemplate>
                    </Setter.Value>
                </Setter>
                <Setter Property="Margin" Value="0,0,0,0"/>
            </Style>
    We ship the generic styles for your components and you can find them in the DefaultStyles directory in the Infragistics Folder on your computer.
    Hope this helps,
    Alex.
