Alex,
Please see the attached solution.
Run the solution and maximize the IE Windows. Now try to drag column10 to right most.
observe the screen. Any fixes for this?
Ramesh.P
Thanks Alex.
Ramesh,
I see the behavior you are describing. I believe this is the expected behavior of the XamDataGrid. You could leave some margin around the XamDataGrid and leave some space so that the dragging-scrolling speed is faster. You could also submit a feature request for optimizing this.
I just saying Colum10. Sorry.
Try this,
Drag Column1 and drop it as last column.(After column20);
When the time of dragging after the current visibile area, the header content scroll is
very slow. Can you catch me?
Hello Ramesh,
Please provide a screenshot of the actual result. When I ran the application and maximized the page, the column 10 is partially visible. You must be running this on a different resolution so I cannot experience the same behavior as you are.
Thanks.
