40
How to manage the editable status by column?
The question is easy. I want one column in grid can not be edited while others can be edit. For now I only know the following codes to control the editable status but it can not work when controling by column.
 <igDP:XamDataGrid.FieldSettings>
      <igDP:FieldSettings AllowEdit="True" />
</igDP:XamDataGrid.FieldSettings>
Some one can help me. Thanks in advance.
  • 69686
    Verified Answer
    Each field's settings expose AllowEdit property as well. This way you will be able to set this per field, and not globally- for the whole XamDataGrid
    <igDP:FieldLayout>
                        <igDP:FieldLayout.Fields>
                            <igDP:Field Name="Field1">
                                <igDP:Field.Settings>
                                    <igDP:FieldSettings AllowEdit="False"/>
                                </igDP:Field.Settings>
                            </igDP:Field>
                            <igDP:Field Name="Field2"/>
