I have a XamCarouselListBox which displays images. I want to drag and drop these images in other part of the grid.
Where should I create the PreviewMouseLeftButton down, up and mousemove events? On image or on XamCarouselListBox or on Grid.
Can someone please provide some sample code snippet or application?
This is what I did:
Item Templete:
<igWindows:XamCarouselListBox.ItemTemplate> <DataTemplate DataType="Imagen"> <Grid Width="150" Height="150" Margin="0,0,0,0" > <Grid.RowDefinitions> <RowDefinition Height="Auto"/> </Grid.RowDefinitions> <Image Source="{Binding RutaCompleta, Converter={StaticResource imageUriConverter}}" Tag="{Binding IdImagen, Mode=OneWay}" HorizontalAlignment="Left" Width="150" Height="150" VerticalAlignment="Top" MouseLeftButtonDown="DragImage" /> </Grid> </DataTemplate></igWindows:XamCarouselListBox.ItemTemplate>
Code:
private void DragImage(object sender, MouseButtonEventArgs e) { try { Image image = e.Source as Image; if (e.ClickCount == 2) { this.SelectedImage.Source = image.Source; ActualizarTexto(); } else { imagen = GetDataFromListBox(e.GetPosition(ImagenesListBox)) as Imagen; if (imagen != null) { this.ImagenesListBox.SelectedItem = imagen; } DataObject data = new DataObject(typeof(ImageSource), image.Source); DragDrop.DoDragDrop(image, data, DragDropEffects.Copy); } } catch (Exception ex) { MessageBox.Show(ex.ToString());
} } private void DropImage(object sender, DragEventArgs e) { try { ImageSource image = e.Data.GetData(typeof(ImageSource)) as ImageSource; if (image != null) { this.SelectedImage.Source = image; ActualizarTexto(); } } catch (Exception ex) { MessageBox.Show(ex.ToString()); } } private object GetDataFromListBox(Point point) { UIElement element = ImagenesListBox.InputHitTest(point) as UIElement; object data = DependencyProperty.UnsetValue; while (data == DependencyProperty.UnsetValue && element != null) { data = ImagenesListBox.ItemContainerGenerator.ItemFromContainer(element); if (data == DependencyProperty.UnsetValue) element = VisualTreeHelper.GetParent(element) as UIElement;
ContentPresenter content = element as ContentPresenter; if (content != null) { data = content.Content; break; } } if (data != DependencyProperty.UnsetValue) return data;
return null; }
I hope this example will help you.
Jaimir G. [MVP]
If your target is a ListView, then you have to get a ListViewItem and not a DataRecordPresenter.
The XamCarouselListBox exposes SelectedItem, SelectedIndex and SelectedValue properties that you can use to get the selected item.
How do I get the selected item/image in my XamCarouselListBox during dragging.
XamCarouselListBox is my drag source.
Hey I tried but got confused with the whole thing.
My Drag target is Listview and has no DataRecordPresenter. what to do?
You can take a look at this blog post - http://blogs.infragistics.com/blogs/alex_fidanov/archive/2009/07/28/drag-amp-drop-with-datapresenter-family-controls.aspx.
It shows how to implement drag and drop from a XamDataCarousel, but the approach is practically identical.
