For the life of me I cannot get a restyled PaneSplitter to display in a XamDockManager. I am using IG 2010.2. I've created this simple lovely window to demonstrate. It just begs for Green splitters, but they are transparent. Am I missing something?
Note the ContentPane style works, but the PaneSplitter style does not.
<Window xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:igDock="http://infragistics.com/DockManager" x:Class="WpfApplication2.MainWindow" x:Name="Window" Title="MainWindow" UseLayoutRounding="True" Width="640" Height="480">
<Grid x:Name="LayoutRoot"> <igDock:XamDockManager Padding="10" Margin="10" Background="#FF0060FF"> <igDock:XamDockManager.Resources> <Style TargetType="{x:Type igDock:PaneSplitter}"> <Setter Property="Background" Value="Green"/> </Style> <Style TargetType="{x:Type igDock:ContentPane}"> <Setter Property="Background" Value="Pink"/> </Style> </igDock:XamDockManager.Resources> <igDock:XamDockManager.Panes> <igDock:SplitPane> <igDock:ContentPane Header="This is Pane 1"/> <igDock:ContentPane Background="Orange" Header="This is Pane 2"/> </igDock:SplitPane> </igDock:XamDockManager.Panes> <igDock:SplitPane SplitterOrientation="Horizontal"> <igDock:ContentPane Background="Purple" Header="This is Pane 3"/> <igDock:ContentPane Background="Teal" Header="This is Pane 4"/> </igDock:SplitPane> </igDock:XamDockManager> </Grid></Window>
Thanks, Andrew.
I was working in Blend and it does not cooperate with making styles for those classes. For some reason Blend recognizes UnpinnedTabFlyoutSplitter, but not the other two. I put them in using VS2010 and they are working fine.
Thanks!
In WPF, the local style is always based on the class type. PaneSplitter is the base class so WPF will never use that as the implicit style. You would have to create a style to target the type of splitter you are trying to change (e.g. SplitPaneSplitter, DockedPaneSplitter and/or UnpinnedTabFlyoutSplitter.
