1235
DataBinding in MVVM pattern
Hi
I'm using the following syntax on the xam side
                                            <ig:XamColorPicker SelectedColor="{Binding Path=OperatorColor, UpdateSourceTrigger=PropertyChanged}"/
and I have a ViewModel that exposes the following property:
 private static PropertyChangedEventArgs operatorColorChangeArgs = ObservableHelper.CreateArgs<OperatorsViewModel>(x => x.OperatorColor);
        private Color? operatorColor;
        [CanBeDirty]
        public Color? OperatorColor
            get { return operatorColor; }
            set
                operatorColor = value;
                NotifyPropertyChanged(operatorColorChangeArgs);
very much like all the other properties in the model ie the LastName property:
   private static PropertyChangedEventArgs lastNameAddressChangeArgs = ObservableHelper.CreateArgs<OperatorsViewModel>(x => x.LastName);
        private String lastName;
        [CanBeDirty]
        public String LastName
            get { return lastName; }
            set
                lastName = value;
                NotifyPropertyChanged(lastNameAddressChangeArgs);
Now as for the OperatorColor it works the first time I load the data and I positively set  the xamColorPicker selectedcolor property and each operator gets its color correctly.
Nonetheless when the user picks another color the change doesn't fire to the bound property on the ViewModel class while all the other properties do so. I don't have a clue.
Do you?
 Roberto Dalmonte
  • 66
    I encountered the same problem and it seems that de binding is default oneway, if you set the binding mode to twoway it works.
    <ig:XamColorPicker SelectedColor="{Binding Path=OperatorColor, Mode=TwoWay}"
    You don't even have to use the UpdateSourceTrigger then.
    Hope this helps.
    Eelke van Helvoort
