65
create AdomdDataSource datasource in code
I've just started using the xamlPivotGrid and the adomdDatasource and I can configure the datasource correctly in xaml but if I try to create it in code I ran into some trouble. I couldn't find a code sample (only zaml) that shows how to configure the datasource in the code -behind. Do you have one that I could modify and add in my application?
I need one that will connect to an olap cube and preset a query (measures, columns and rows)
Thanks.
  • 7922
    Verified Answer
    You can use the sample below
    AdomdConnectionSettings connectionSettings = new AdomdConnectionSettings();
    connectionSettings.ConnectionString = "Provider=MSOLAP.3;Integrated Security=SSPI;Persist Security Info=True;Initial Catalog=Adventure Works DW 2008;Data Source=local;MDX Compatibility=1;Safety Options=2;MDX Missing Member Mode=Error";
    AdomdDataSource xmlaDataSource = new AdomdDataSource(xmlaDataProvider)
        ConnectionSettings= connectionSettings,
        Database = DataSourceBase.GenerateInitialDatabase("Adventure Works DW 2008"),
        Cube = DataSourceBase.GenerateInitialCube("Adventure Works"),
        Columns = DataSourceBase.GenerateInitialItems("[Columns]"),
        Rows = DataSourceBase.GenerateInitialItems("[Products],[Drivers]"),
        Measures = DataSourceBase.GenerateInitialItems("Value1,Value2,ROI")
    Regards
    Todor
